Anders Hoveland
- Joined
- Sep 1, 2012
- Messages
- 858
Try a red rose with green leaves. Then compare to incandescent. I think the difference will be clear. Or skin tones (assuming you are of European ethnicity). Skin tones look rather greyish under LED.Colors of most objects look fine under this bulb.
Use a standard medium base 750 hour bulb or an energy saving halogen. Do not use a "rough service" bulb or any other shape for this comparison, as the color temperature will likely be much lower than normal. And do the comparison at night, because a little ambient daylight sneaking in the house can really skew the results.
LED light has a different spectrum of frequencies, so certain colors may look a little different (reds, bluish-greens, certain bluish-purple/violet colors). If you are concerned about the red colors and appearance of skin tones, you can at least get the LED down lighting that has a CRI above 90, since these are enhanced with additional red frequency.
