That would be the new Coast/Led Lenser M7R.
The M7R Rechargeable LED flashlight has Coast's innovative magnetic charging system that charges the included 18650 lithium ion battery while inside of the flashlight. The charging cord magnetically attaches to the tail switch of the Coast M7R LED flashlight. The Coast M7R flashlight can be charged through your computer using the USB* plug or from any AC wall outlet using the included AC (120V) adaptor plug. The charging status indicator will turn green when charging is complete.
The Coast M7R LED flashlight has a total of 3 brightness levels with up to 220 lumens maximum (shines a beam up to 837 ft). The Speed Focus system on the M7R allows you to adjust from spot to flood beam and to lock-in the desired focus by twisting the head of the flashlight.
Features of Coast M7R LED Lenser Rechargeable Flashlight:
• 3 brightness levels:
Max - 220 lumens, shines up to 837 ft or 255m (press & hold switch for Max)
High - 180 lumens, shines up to 771 ft, runs for up to 12 hours
Low - 30 lumens, shines up to 328 ft, runs for up to 20.5 hours
• 3 lighting programs (from off, press switch 4 times rapidly then click on to change program mode)
1. Professional - 100% power, low, flashing, SOS, strobe
2. Easy - 100% power, low
3. Tactical - 100% power, strobe
• charging indicator
steady red - charging
steady green - charging is complete
flashing red - error (wrong position in charging station)
flashing green - determining the state of the battery (takes up to 5 minutes)
• powered by a 18650 lithium ion rechargeable battery, included
• tailcap switch for momentary on and constant on/off
• Speed Focus - adjustable spot to flood focus (turn the head of the flashlight to lock)
• magnetic charging system charges the battery while inside of the flashlight using the included
USB* charging cord; also included AC (wall) adaptor
• anodized aluminum body
• O-ring sealed for water resistance
• includes belt clip (fits belt up to 2.25" wide)
• measures 6" long with a 1.5" head diameter
• weighs 7.3 oz with battery
• includes M7R flashlight with rechargeable battery, USB* charging cord with AC adaptor,
magnetic docking station, belt clip, wrist lanyard and molded case
• made in China
• limited lifetime warranty through Coast
