mikevelarde
Fm's socket arrived today!! put in the WA1185 and Wow....!!:devil:
Help Support Candle Power Flashlight Forum
Should the bulb be FULLY seated as far in as possible?:thinking:... 3rd Run BiPin Socket has deeper holes than my 4th Run ones.
It's just barely enough to properly seat a WA1185 for me.
Push firmly but carefully.
by theGoochShould the bulb be FULLY seated as far in as possible?:thinking:
I don't have any problem inserting the bulb so that the little glass tit on the bottom of it seats in the recess in the socket.😱
When fully seated, the overall assembly is quite obviously much shorter than my LF HO-M6R bulb.😎
It seems to me that puts the filament height too LOW, as it gives a very noticeable donut in the beam and adding shim(s) just makes it worse.😗
I finally got a decent beam by leaving the bottom of the bulb maybe 3/32" up off the socket.
Thanks,
Tim
Thanks,
Tim
These sockets are designed to use with several different type of bulbs and each bulb has different fillament height.
See bulbs picture in this thread.
If you are using WA1185, bulb pins should not be all the way in and no washer needed.
Once you find the correct fillament height, hold the removed head aimed to your face and twist the socket inside reflector to make sure bulb is centered and not wobbling.
