JordanOfOz
- Joined
- Jan 16, 2009
- Messages
- 2
Hi all,
I'm going on an extended bicycle tour later this year and I'm looking to use a TuneCharger not unlike Alex Lockhart's system:
http://www.crazyguyonabike.com/doc/page/?o=3Tzut&page_id=68041&v=Fy
I'm hoping to keep things a little simpler. I will be using a Son Dynamo hub and the TuneCharger to charge a ~12v bank of Lithium Ion batteries. Unlike Alex's system, I won't be powering lights directly from the 12v supply - I'll be powering a AA battery charger with a 12v input and a USB hub with a 12v input. All my lights and nerdy devices will use AA batteries and/or can be powered via USB or 12v
When used with a hub dynamo, the TuneCharger manual recommends using two zener diodes back to back to limit the input voltage, which in turn limits the drag experienced:
(page 22)
http://www.tunecharger.com/wp-content/52_mtc_43_evaluation_module_d.pdf
So I was thinking it would be nice to have a three-way switch that would give me the following options:
1: Disconnect the dynamo from the TuneCharger - minimal drag for climing hills
2: Connect the dynamo to the TuneCharger with the zener diodes in place - for normal cycling on flat terrain.
3: Connect the dynamo to the TuneCharger bypassing the zener diodes - for cycling downhill, giving maximum battery recharging and providing some extra drag.
Ideally I would have the TuneCharger and the above circuit all contained in some sort of rain-proof enclosure.
The enclosure will need:
- an input connector from the dynamo hub (RCA?)
- an output connector to the battery (or maybe not)
- two output connectors to power the USB hub and AA charger
I'm still debating with myself whether to include the 12v lithium ion pack in the TuneCharger enclosure, or use something like this:
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2819
I've even considered including the powered USB hub inside the enclosure and wiring up waterproof USB sockets. This would be really handy, as I'll be using a Garmin eTrex right next to it, which can be powered directly by USB, and it would be nice to be able to mount any other USB/5v powered gadgets nearby on the bike.
If anyone could help me with any of the following questions (or if you have any other comments) I'd appreciate it:
1: What sort of 3-way waterproof switch should I use and how would I hook up the power input/zener diodes/power output? Would it be better to have two switches: connection to dynamo on/off - and - zener diode on/bypass
2: Can you recommend an enclosure to use?
3: Everything I've read seems to indicate that I can just hook up the 12v AA charger and the 12v supplied USB hub (and any other 12v devices I need) in parallel to the output of the TuneCharger. Is this correct?
Thanks in advance!
(page 22)
Thanks in advance!
