sig-in-tx
What are the difference's in the two? Is one better than the other?
http://www.brightguy.com/accessory_results.php?Sku=PEL3850071245
Help Support Candle Power Flashlight Forum
Phaserburn said:Both pull 4A; the nicad at 7.2V, the SLA at 6V. The Nicad Big D has longer runtime because the pack is 5Ah capacity; the SLA is 4Ah.
Phaserburn said:Both pull 4A; the nicad at 7.2V, the SLA at 6V. The Nicad Big D has longer runtime because the pack is 5Ah capacity; the SLA is 4Ah. Overdriving the SLA at 7.2V produces ALOT of output, over 1000 bulb lumens. I'm talking about the high output versions in both cases; there are corresponding lower output versions for each type of Big D; they're no slouch, either.
lexina said:something doesn't add up. if both pull 4A and one is 7.2V while the other is 6V; they shouldn't both be 24W (as is stated on the web-site).
sig-in-tx said:I didn't notice it tell after I placed my order, I ordered the Rechargeable NICAD bulbs. Part Number: PEL3853 So now I'm not sure what to feed it? Did I mess up?
That's the ROP LE, but the bulbs may demand more current than your salvaged cells can provide.sig-in-tx said:Any one have any better ideas to drive the bulbs better? I was thinking about a couple of 18650a I took out of a old laptop, but being a unprotected cell I'm a little gun shy.
