D
**DONOTDELETE**
Guest
If you have one of these and want more battery life, do the following:
1. Remove grey plastic cover.
2. Remove one LED.
3. Bend leads on remaining LED so that it is positioned more or less in the center of assembly on top of the grey plastic "box".
4. Drill hole in grey cover above LED.
5. Re-fasten cover over LED then (this'll sting a bit) cut off top of LED enough so the LED doesn't touch bottom of glass.
6. Put everything back together and you have twice the batt. life and it works just as good, or better.
CJ
2. Remove one LED.
CJ
