BLF GTvn - Sky Lumen's Farthest Thrower
vinhnguyen54
CPFBA
Shared Features
  • Factory Link Here
  • Bright ring around hot spot
  • Hot spot filled and ultra intense
  • Email for accessories details
  • Light weigh ~5lbs with 8 cells
$700 Spec 1
~4500-5000 Lumen, 1.5-1.7Mcd, +2450m Throw
  • CFT-90 6500K + DriverVNX3
  • Turbo can run continously
  • Circuit does not overheat
  • Light operate on any number of 18650
  • 1 18650 can hit 1-1.2Mcd
  • Ultimate Reliability
$700 Spec 2
~5500-6500 Lumen, 2-2.2Mcd, +2828m Throw
  • Turbo run 1-3 minutes only before circuit overheat and will signal for manual step down
  • Must run at least 4 VTC5A Button Tops
$335 Spec 3
~6500 Lumen, 1Mcd, 2000m Throw
  • XHP70 6500K Shave Dome = ~ 4500K Tint
  • Factory Ramping UI
  • LG 3500mAh Recommended
vinhnguyen54
CPFBA
Re: BLF GT70vn - Budget Searchlight
GT70vn with 70.2 SD matches the GT with XHP35 HI 1Mcd intensity but with ~3 times the output!
twistedraven
Probably 3 times the battery sag too. Sure must be impressive the first couple of minutes tho, not to mention the lower cost! Very tempting.
vinhnguyen54
CPFBA
Is it worth it or should I save a bit more for gtvn2?
Twice the money but for me its twice the light. I am also not really into the yellow shave dome tint of the corona althought that is not too bad outdoor at distance.
vinhnguyen54
CPFBA
MT35+ VS GT70vnSD + GTvn90 V2
1.2Mcd VS 1Mcd VS 2.2Mcd
2000Lumen VS 6500Lumen VS 5500Lumen
$270 VS $335 VS $700
All considered which one would you prefer?
twistedraven
Yikes, that's very green, makes the brown post as green as the leaves.
Dio
Which makes me wonder how the camera was setup..
Mine was white leaning towards blue in stock form but now that it is dedomed it is just perfect with a barely noticeable yellow/green corona.
I wonder if there is just a massive tint variation (shouldn't be as they are claimed to be 1A emitters, not simply a random A/B/C/D lucky dip) or if in fact the GT70 dedomed version looks much whiter and the CFT90 much bluer in real life.
Compared to my TN40Svn 5000K it just looks cool white. Also, unless you are super keen on having a massive light (and I mean MASSSSSSIVE) or plan to dedome it, then I would go with the TN40Svn as there is seriously little difference between the two. Even when dedomed, the GT70 is not what I consider a major upgrade over the TN40Svn. That Thrunite is just a monster after Vinh did his thing but the GT70 does have more thermal mass so should run at higher levels for longer and the 8 cells VS 4 cells does seem to offer greater runtime but that should be expected.
EDIT: yeah, I just had another look and if you compare the 6500K XHP35 HI BLF GT to the CFT90 version, you really see how blue the CFT90 appears. That or the XHP was mislabelled and is a 4000K NW version....??
twistedraven
Production GT is 4000k XHP35 HI. Only pre-production review samples were 6500k. I had Vinh put 4 of them in my TN40 and the tint is pretty decent.
Dio
I thought the "cold white" option they had on their website for the XHP35 HI GT's was 6000-6500K - is it meant to be neutral and warm or is that a relatively new option some people wont know about?
twistedraven
Possibly a relatively new option, though I haven't heard any news of it. What site did you find the option on?
Dio
I stumbled across it on the Lumintop website
