Thanks. I didn't want to just recommend one company since people tend to think it's spamming. S-KY lasers is very responsive to emails. I haven't worked with CNI but they were the only other one I could think of. Anyway, if need be I could use my internet company.
S-KY seems to be knowledgable about using TEC (Thermal Electric Cooling) to allow lasers to run at higher power for longer. The laser I ordered from them a few days ago is spec'd to run 10-mins continuously before attenuation sets in due to heat.
I would also like to thank drlava for introducing this company to me via a post. His recommendation to me regarding TEC was also to "add a large heatsink on the output transistor on the power supply board", then I'd be able to run it over an hour on a single charge of the 18650 cells.
However, I needed a portable laser that is fairly durable, can project 1-2 miles for aligning antennas. So while I will have a laser that can burn stuff, my use is more long range.
If you want a serious burning laser, try researching CO2, but be sure that it is aligned with a 2nd visible laser so you can see. CO2 lasers are used for cutting and welding metal. Definately need goggles, and the 10.6 micron wavelength reflects very well off of metal, so you'd have to be careful. I'd try around 5 Watts or so for some good burning. However, being invisible, it is critical that you have an overlap beam, of perhaps green.
