Boosted Thor ~3X output
Candle Power Flashlight Forum
Help Support CPF:
Status
Not open for further replies.
Re: Thor Spot Light information
Count me in.
1 for sure. /ubbthreads/images/graemlins/happy14.gif
2 most likely. /ubbthreads/images/graemlins/grinser2.gif
More depending on cost. /ubbthreads/images/graemlins/sssh.gif
Theepdinker
How much would it be for:
1. bare board (no components)
2. bare board + components (requires soldering components on)
3. Assembled board (components already soldered on board)
Thank you.
if you offer a turn key black, im most definately in for this.
cant find a thor locally so might as well have a turn key one shipped /ubbthreads/images/graemlins/smile.gif
Well, an event that I've been waiting for is due to happen very soon.
After that, I'd like to start a new thread, and have all interested parties to post there, and if someone would be willing to keep the count, or maybe we can do it as a run-on total post, where you add your name to the list, that would be great.
I don't know the total cost yet, as it would be largely influenced by how many folks want total. Costs keep dropping alot at 20, 100, 200 total, with different break points on various components and the PCB itself. It really makes a huge difference on the cost of it all.
The default board will be set to a 2X brightness level, and you can adjust the output level up to this yourself, while it is running. This will be about 15V. Going above this is done at your own personal risk, but can be done by modifying the resistors on the board.
For those interested, please read up from the beginning.
I would prefer to sell a fully assembled board, as I can test it all to make sure it is working before it goes out, and replace any parts that are defective. Thoughts?
I'm an insider! I know the secret "event". /ubbthreads/images/graemlins/nana.gif
Everybody's thoughts & questions.
How soon?
How much?
Theepdinker
The more I read about this the more I like it /ubbthreads/images/graemlins/smile.gif
@25.00 from CostCo. I put a few of them together to give as gifts! I'd be up for 3 - 5 boards (either bare or unassembled w/components depending on costs)
Brilliant (and again thanks for your expertise), my only question,
Any chance of getting one made for 24 wolts (i.e. about 30 amps), to run an aircraft landing light? So, then it could go up to 30 volts?
Thanks!
[ QUOTE ]
Thanks!
[/ QUOTE ]
Cheese may as well look into enough power to run two at a time /ubbthreads/images/graemlins/grin.gif you and I both know you will never be happy with just one /ubbthreads/images/graemlins/crackup.gif
Later
Kelly
I could make a custom one that would do that, but it's going to take one heck of a battery. If the battery didn't sag, you'd be pulling over 60 Amps at 12V.
Hi, this is Mark Weiss from Connecticut. I discovered this forum while doing some research on the Thor X Cyclops on Google. Nice to see a discussion on spotlights. I never knew there was an enthusiast group into 'overclocking' flashlights! /ubbthreads/images/graemlins/smile.gif
I just bought one of these Thor X Cyclops lamps from COSTCO yesterday. After giving it a full charge, I fired it up today and, yes it was quite bright, although, it didn't look like 10 million candlepower to me.
I also own a Brinkman Q-Beam Big Max, which is a sealed-beam spotlight with 150W filament. That has been my benchmark for 20 years (bought it in '83).
I recently bought a Vector spotlight, also at COSTCO. It's nice and portable, and reasonably bright.
Here's what gets me: Over the years, it seems like candlepower ratings are being inflated. 10 years ago, I saw the first 1,000,000 CP spotlights and they were a fraction as bright as the Q-Beam.
So I have the Thor, the Vector and the Q-Beam (with not so fully-charged 4.5 Ah battery attached by a 16 ga wire) and thought I'd do a comparison this evening. I set them up on the deck aiming up at 45º into the trees. The Thor was quite bright, as expected, and very white (being it was just fresh off the charger), but when I switched on the old Q-Beam, although it's beam was a little yellowish due to the lack of charge on the battery, ITS beam was easily as bright as the Thor's central point, and twice as wide as Thor's. Q-Beam's peripheral light was easily 50% brighter than Thor's. If I had provided a full 12VDC to it, it would have been even brighter. It draws 13A at 12VDC.
Now here's the kicker: Q-Beam is rated at 300,000 CP.
As for the Vector, it wasn't even in the running. It was like shining a flashlight next to a car's high beams.
Maybe someone can explain this anomaly. Has there been a change in measurement standards over the past 20 years?
Based on the Q-Beam, I would expect 10 million CP to be as bright as one of those mercury-vapor arc lamps used to light up the clouds at grand opening events. What it boils down to is that the Thor is a nice lamp, but it's more impressive to look at than to operate. I expected it to tromp the Q-Beam by several orders of magnitude, but it's only a close second instead.
Despite that confusion, I'll still keep the Thor; it's handles/stand make it a convenient work light for emergencies.
Maybe if I figure out how to post a pic, I'll do a head to head comparison shot and post it.
Jarhead has quite a nice little chopper/step up circuit there. It never occured to me to do that with the headlight system on my Ford Explorer, which has one of the worse lighting systems in the history of automotive lighting. I've got Phillips XtraVisions in there and still can't see where I'm going at night. /ubbthreads/images/graemlins/smile.gif
just got my Thor-X from Wingerr last night. Im ready for the board. please put me down for one.
Well, /ubbthreads/images/graemlins/wink.gif um, /ubbthreads/images/graemlins/icon15.gif er, /ubbthreads/images/graemlins/thinking.gif well, /ubbthreads/images/graemlins/jpshakehead.gif , maybe that's why I said I'd buy at least one board. Hmm, overdriven 2,000 watts, that should be a good bird cooker. Then again, why stop at 2,000 watts?
cheese
Newbie,
You're right, I think /ubbthreads/images/graemlins/thinking.gif having 2 1,000 watts lights may be a bit much/ubbthreads/images/graemlins/mpr.gif, since 60 amps would not be very portable. On the other hand, 30 amps is pretty doable. SLA's always sag a bit (well, a lot) and I thought of getting 5 6 volt cells to compensate (even starting off with 4 to do a pseudo "soft-start" and then hooking in the 5th), but your solution seems even better. Finally, why do I need a 1,000 watt light? I don't know.
cheese
cheese,
Do like sway said, get two Thors.
Mount them on a helmet.
You'd have "Super Cheesy Head Lights". /ubbthreads/images/graemlins/str.gif
Theepdinker
i would like to get a TK in black.
Status
