Hello,
I have several projects in the works, but am in need of some custom machining (which, unfortunately I cannot do just yet). The first is fairly simple, I have a DSpeck AA extender that I need bored out to CR123A internal diameter. The second is more of a multi-part project. I am in need of some press dies for use with high pressure experimental powder metal work. It would basically involve circular bars of 4130 steel, two of diameter 1.75" and two of 1" diameter. I would need concavities machined into one face of each cylinder, with the opposite end machined as flat as possible. The depressions need to be approximately 5/32" deep at the center with an even lensatic taper to the edge (kind of a bowl shaped depression). The rods would be about 1.5" long. If anyone can do this, please let me know, and an estimate would also be great. Thanks!
D-R
D-R
