StainlessSteel
OK.
I have been in the market for a green laser for a while. I couldn't find the one with the features I wanted. I wanted one that took 123a batteries, was DURABLE, and had a constant on option, and a surefire-like switch, NO delay in turning on, & waterproof would be a huge plus.
This isn't the brightest of all the green lasers, the specs SAY it is 10mW, and it is listed as a Class 3B laser, the little sticker says it is <15mW.
It isn't night yet, so no beam shots... cause a green dot on a wall does no one any good.
I used a Surefire L4 as scale.
Here is the box you get:
You slide this plastic case out. It isn't pelican/storm/starlight quality, but it is a nice case.
Here is the laser, the lanyard, and a space for a battery in the upper right. It comes with a battery already. Also, you could cut out additional batter spaces in the foam, which is cool.
Here is a close up of the Beamshot with an L4 for scale.
Here is the inside of the pointer.
Here is the tailcap. It is DOUBLE O ring sealed. As the literature SAYS the laser is WATERPROOF to 40 meters. **You must clean the threads well, and lube them WELL with Nyogel** The threads come DRY and dirty. But a quick wipe down, and lube fixes that quickly.
Don't know what Nyogel is and does?.... read this, and then buy some.
www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=1363
I will make a blanket statement: "Anyone who has a lot of flashlights, or lasers, should own a tube of Nyogel. It is just like maintaining a firearm.
Here is a close up. You can see the sticker, <15mW, Class 3B. You can ALSO see a little window on the top that glows GREEN when the laser is ON.
Please keep in mind, this is NOT A WEAPON LASER. It has NO adjustments, But is it advertised as "Shock resistant."
I bought this for 2 reasons. #1 I wanted a laser with EXACTLY these features for a long time, and this was the ONLY one I could find. and #2 I wanted to see the quality of Beamshot Lasers. I would VERY MUCH LIKE a weapon mounted green laser, but I want one that is durable, and has adjustments that hold zero.
So, I am gonna play with this for a while, and see how it holds up.
It is 1" in diameter, so I plan on mounting it to a weapon, to see if it handles the recoil... it IS advertised as "Shock Resistant."
UPDATED MORE PICs, Of Instructions and WARRANTY.
Here is the warranty card included in the BOX. It is 1 year.
Here are the instructions, this is advertised AND listed in the instructions as a 10mW laser. This is actually BRIGHTER than advertised.
