I wonder how much current you could safely put through an XP-G if you use a big 12 gauge wire for a power lead to heatsink it. Seems easier/cheaper than the other alternative of using a 4mm copper rod, though I suppose instead of an official "rod" you could just get the largest diameter solid core copper wire you can locate, or for more cost effectiveness twist together several strands of 14 gauge, solder plate the end and cut, lap it to a flat surface... think I may end up trying that some day.
Wouldn't it be nice if they made some XP-G with an integral lens that attempted to focus a lot more?
Anyway, if you start lining the sides with copper sheeting it is likely you cut down on the RF range, but we don't know how much margin there is to play with on current distance vs minimal distance you require of it.
