Brightest 5mm Warm White for Pelican 2440?
LEDAdd1ct
Hudson Valley
I wasn't sure if this was a flashlight question or an LED question, so please forgive me. :)
I would like to "upgrade" my trusty Pelican 2440 as seen here:
http://pelican.com/lights_detail.php?recordID=2440PLB
The light currently has five 5mm white LEDs in it, and as spec'ed in the link above, the light is rated at 33 lumens. The manufacturer does not specify whether this is OTF, so we'll leave that up in the air for now. The light works great, but a warmer tint would make it perfect for emergency *and* general use. The only problem is, I am not sure which LED to pick!
33/5 is 6.6, so if we hold Pelican's claim as fact, each LED is putting out 6.6 lumens. I would like a warm/neutral white LED with the following characteristics, if possible:
1) 5mm
2) as bright or brighter than the original (estimated at 6.6 lumens) at about 20mA
3) a beam angle suitable for flashlight use, i.e., should project a good amount of light forward but still leave plenty of spill. I'll try and get a picture of the integrated plastic reflector up later.
4) will not fade *appreciably* over time.
These criteria being the case, I scanned the warm white 5mm LED thread and asked a respected 5mm expert, and came up with the following candidates. I will state here that I am, at the moment, biased towards number one because of the pros I list. Here are the candidates:
1) http://tinyurl.com/mkjmtd
Pros:
a) JELED is a known seller with a good reputation
b) rated 28,000 mcd at 20mA
c) nice warm white that is not too yellow
Cons:
a) come from Hong Kong (long wait time?)
b) don't know how they will fare over time
Other:
Viewing angle is 25 degrees. Is this good or bad for the flashlight listed?
2) Radio Shack 276-017 as seen here:
http://tinyurl.com/m8dj6p
Pros:
a) this LED is held in high esteem by many on the forum
b) the tint is supposed to be nice (4200k according to JohnR66)
c) did not fade at all in JohnR66's tests
d) rated at 25mA
Cons:
a) rated at only 7,000 mcd when driven at 25mA
Other:
Viewing angle is 30 degrees. Is this good or bad for the flashlight listed?
3) Light of Victory Warm White
http://search.ebay.com/370080285721
Pros:
a) Light of Victory LEDs seem to stand up well over time (don't fade according to JohnR66)
<---this is incorrect; see JohnR66's post below correcting this.
b) rated 22,000 mcd at 20mA
c) held in high regard on the forum
Cons:
a) at 3000 kelvin, I think they may be more like candlelight, and less suitable for flashlight use (one man's opinion)
b) come from Hong Kong (long wait time?)
Other:
Viewing angle is 20 ±5 degrees. Is this good or bad for the flashlight listed?
These three candidates appear to be the top three choices with respect to manufacturer reputation, potential longevity, and tint. The Light of Victory and Radioshack LEDs are reported not to fade, but the L.O.V. seems too golden/yellow, and the Radioshack seems too dim. I am leaning heavily towards candidate number one, the JELED warm white.
What do you guys think? Is this a sound choice? Am I missing anything (technically/electrically/optically) or (other candidates)?
LEDAdd1ct
The "Light of Victory" (LOV) warm white I tested was a flux style LED. I never tested those WW 5mm LOV LEDs. I have not tested any ebay 5mm white that did not fade (except for one dim one). In fact I have not tested any 5 or 3mm WW that did not fade. I have not tested any Nichia WW LEDs though. They should not fade.
The Rat Shack 276-017 LEDs are nice, but it would make your flashlight a flood light. It would lack throw and seem dim.
At 6.6 lumens per LED it sounds like your light may use Nichia GS LEDs. You will be sorely disappointed with anything warm white you put in it brightness wise. You would have to look into .5 watt 5mm LEDs. This would require changing the driver/resistor and dealing with the extra heat.
Thank you very much for correcting me. I did not realize this, and I corrected my mistake in the original post. I think I will leave this light well enough alone then, unless anyone else has any other thoughts, or knows of a warm white 5mm LED that does not fade...
It's a Pelican, so it's minimum OTF.
I did not realize Pelican listed their lights in OTF lumens! If this is the case, then it may well already be using Nichia LEDs.
I did not know where else to post this, so I thought a thread already started on the light would be a suitable location. This was the only place I could find the specs for this light. When I tried contacting Pelican directly, they would not tell me the type or kind of LED. So if nothing else, this can serve as a record for the materials the light is made of.
Specs:
"LED Flashlight
*** Finding dependable lighting in a blackout situation is no longer a problem for the owner of the Pelican Products GLOW-In-The- Dark # 2480 ELS (Emergency Lighting Station).
*** The ELS houses a long lasting bright Emergency 5-LED Flashlight in a clear jewel case, engineered for attachment to various surfaces.
*** The Photo Luminescent body adds instant visibility in a black out situation.
*** The titanium batteries give the light 90- hours of battery burn time and up to seven year shelf life.
*** The 5-LED array beam shines 21-Lumens of brilliant light and is activated by a tail switch for easy one handed operation. MATERIALS:
*** Body: ABS Resin.
*** Lens: Polycarbonate Resin.
*** Contacts & Spring: Stainless Steel.
*** "O" Ring: 70 Shore, Ethylene-Propylene.
*** Light Source: (5) - 5mm White Nichia LED's.
*** Switch Type: Push Button û rear mounted.
*** COLORS: Photo Luminescent.
*** BATTERIES: 4-Energizer Titanium AA Cells.
*** BATTERY BURN TIME: 90-Hours.
*** VOLTS: 6.00.
*** WATTS: 3.66.
*** LUMEN VALUE: 21."
Source
