brightest edc
GrandPixel
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
x____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! 🙂
____Less than $25.
____Less than $50.
____Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
x____I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
x____I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
x____Keychain size.
x____Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
x____LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
x____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
x____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
x____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
x____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
x____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
x____Less than 1 yard/meter (reading, other close work)
x____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
x____5-20 yards/meters (check out a noise in the backyard)
x____30-50 yards/meters (I have a big backyard)
x____50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
x____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
x____Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
x____30-60 minutes (I have plenty of batteries just ready to be changed)
x____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
x____Slightly Important (Walks around the neighborhood).
x____Very Important (Camping, Backpacking, Car Glove-box).
x____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
x____I don't care.
x____I don’t know.
____A simple on-off with only one output level is fine for me.
x____I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
x____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
x____I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Jetbeam PA10 has 650 lumens with li ion cells, but you lose all the modes. NiteEye 15 is a bit larger, 500 lumens and has brightness ramping.
I think you'll have a hard time finding something keychain sized, really bright, and runs for 30+ minutes on high. Also, small lights have smaller reflectors, meaning a wider beam and less throw. More output also means a larger die emitter or more emitters, also cutting down on throw.
The Zebralight SC600 might be one of the brightest lights at ~4". If you want a smaller light, look at the 1 AA or 1 CR123 lights that can take Li-ion batteries and have the Cree XM-L emitter.
For a small size EDC (2 - 4"), I agree with Gunner12 in listing the Zebralight SC600. It is compact and very bright. As for keychain size, I personally like the iTP A3 EOS Ugraded version. It is a mini AAA light with 3 output levels. It puts out an impressive amount of light for its size. Manufacturer claims 96 lumens on high setting. This might be debatable, but it does light up the side of my house at 100'. I recommend a AAA Ultimate Lithium cell or a NiMH cell in this light as they will not leak. Using a 10400 lithium ion cell will produce a lot of light (and heat). Do this at your own risk.
