shipwreck
OK, I checked the tracking # when it didn't come today - It wasn't shipped for 3 days, despite the claim. And now it is in Houston - will be here Monday 🙂
Help Support Candle Power Flashlight Forum
I'm not to bothered as i am know trying to dismantle it but the bulb holder is spot welded to the heat-sink and the hole thing is tide together with the wires
i have-played with it a bit and it gives the odd flash of light now and then i think the very thin wires may be the problem
i will try to dismantle it and see if i can rewire it there is a faint smell of burnt from the bulb-holder not the LEDs
the batts were ultra-fire LC18500 1600mAh 3.7v x3
OH-and i ordered 3 so still have 2 to play with :laughing:
i will let you know how i get on
Hi again
i got the drop-in apart
had to cut the wiring on inspection found one of the wires at the head was loose very loose to the point it fell out in my hand
i don't think i will be able to fix it as the wiring and solder joints are tiny i had to use a aspheric lens as a magnifying glass to see where the wire was fixed
i do not have a soldering iron for such fine work
it maybe that the higher voltage i put through than recommended heat the wiring and loosen it but those wires are really tiny about 1MM that is with plastic insulation
i will probable harvest the LEDs
it is a great drop in for the money and i like that it also runs on lower voltage making it very versatile i ran it on 2D-size rechargeables 2.4v way up to 12.20v and it will run on a number of combination of batts and voltages in between i will run them at 3.6 and 7.2 v =3c-cell and 6AA-cell in 6AA to 2D in a 2D Mag i will buy more at the price it is a - (Mags best friend)![]()
Couldn't have said it better...... 😀
Why is it that every time I hit the newest post button for the Munroe Design Mega Dangler I get directed here to a thread I never subscribed to?
http://www.candlepowerforums.com/vb/showthread.php?t=277794
