Any interest in a $99 kit price for gili-6 gen III?
Yes Matt, I'll have one.
T.
Help Support Candle Power Flashlight Forum
I know I said I wouldnt, but I did and I cant help myself.
http://img594.imageshack.us/img594/3562/frontlc.jpg
http://img266.imageshack.us/img266/7676/backqm.jpg
Reduced weight.
Reduced cost.
Reduced complexity.
So the obvious visual difference is moving he switch to the back plate. Anything else noteworthy?
Some slight internal differences to reduce weight by about 15~20 grams
Are there any aesthetic changes you would like to see?
The centered cable glad and top mounted switch is nicer.
A feature for an indicator led should be optional. I would not use the led and would not want to have to plug a hole. But I'd like the option.
Black works well with this design but I think a natural anodized finish would appear nicer, longer.
Could you leave more material for the mount hole. A square around the location. The taping into the fins looks a bit weak.
The internal cable holes - to the front led and switch cavity could be smoother/smoothed before anodizing. Things were sharp inside.
I haven't received my Gen II yet, so I might have some suggestions after doing that build, but one thing I would like to see is a location for the MaxFlex STAT LED. I know you're working with some really tight spaces, but if you could find a spot for a 2mm LED (or smaller if they exist) that would be great. Or maybe there is a illuminated version of the switch you are using that could be substituted?
before I can take it outdoors for a proper shakedown ride.Is there another supplier for the XPG modules and optics other than Cutter?
Twice now I have tried to make an order from them, but once I get to the shipping adress page, It will not allow a US state to be entered. I do not know if they just do not ship to the US or if it is a web page issue, but first time i tried was over a month ago. :thinking:
Thanks, Joe
Thanks, Joe
I WIN!
I need sleep... 1AM...
This looks like a good helmet mount for the Gili 6 and at least one possible source: http://www.chainreactioncycles.com/Models.aspx?ModelID=23534
Nice! Does that mount come with the bottom plate part (It is not shown in the retailers picture)
