I have some modules left that I used with the Torch and all my Mag Hotwire builds. These are a tight fit I used to put them in the freezer then heat the body up with a heatgun. You can also take the anodize off with some sandpaper. They measure 1.348"
These where designed for a tailswitch but you can easily take the PCB off the bottom and solder to the Bi-Pin holder directly.
$35 each delivered (US)
