Building Balanced Battery Pack
Paperdesk
Hello,
I'm wondering if anyone can point me in the right direction to find instructions on how to build a balanced battery pack for a can light (in this instance a Light Monkey Salvo HID). I plan to use 18650's. Thank you!
Ted
archimedes
Moderator,
Staff member
CONUS, top left
The Special Applications Lighting subforums do not see nearly as much traffic as the main flashlight forums here.
It may well take more than 24 hours for a response to such a specialized question.
If you can be patient, however, the experts here in the Dive Lighting forum are typically quite helpful ....
Paperdesk
Ah, so nice to bump into you here Lucca! That spot welder looks really interesting, I wish he were still selling it!
Question, is there any reason not to build a balanced charging battery pack? I just haven't seen any and got to wondering if there might be a good reason.
Ted
DIWdiver
Connecticut, USA
Balancing a battery pack that suffers any significant imbalance involves dissipating a significant amount of heat. Most balancing is done by the charger, not the battery, because the charger is better suited to dissipating the heat. If you look at most commercially made packs, they have two large wires for the main current, and several smaller wires, usually in a different bundle, for balancing.
I thought my drill/driver batteries had only two connections, so I just went and looked. Sure enough, two large and three smaller terminals.
So-called 'hobby' chargers are designed specifically for the purpose of charging multi-cell LiIon packs with balancing connections. Most of them will handle packs with 2 to 6 cells in series. I'm sure a search would reveal a number of threads on CPF discussing them. Google would find much more.
arek98
New Jersey, USA
Go here https://vruzend.com/tech-center/ and read their articles.
They sell kits for building battery packs, most likely not suitable for diving canister but they explain process of building pack pretty well.
Especialy lern about BMS (battery management system) used for protection and balancing cells
You can find stuff for building packs on www.batteryspace.com
They also sell whole battery pack and can make custom one.
Idealy you want matched cells for battery pack and if some company makes packs they have larger pool of batteries to pick ones for particular pack.
I mean batteries obviously should be identical (part number) but ideally they should have similar capacity and internal resistance.
alpg88
balance\hobby chargers equalize without making much heat, they just continue charging weak cells, they monitor each one, balance pcb otoh do balancing by draining cells that have most voltage, that does produce heat. but also it depends on pcb, some make little heat other a lot more.
i used to build packs with pcb that had balance function, but i figured using hobby charger would be simpler, and involves less circuits, but if that is not an option, (can only use 2 wires for charging) balance pcb is the only way.
