Lurveleven
I'm considering getting the Pila GL2R light as an EDC and as backup light when using bigger lights. Comparing the specs to SL Strion, both have the same battery spec (3.7V 2000 mAh), but the Strion beats the Pila in both brightness and runtime, i.e. 70 minutes of 116 lumens vs 50 minutes of 80 lumens. Would it be possible to put a Strion bulb (or another bulb that is even better) in the GL2R?
Does there exist other lights running on one Pila 168A battery that I should consider instead?
Sigbjoern
Sigbjoern
