<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by yclo:
Can someone please explain the difference between the halogen bulbs used in home lighting that has about 5000 hours bulb life, and the xenon-halogen bulbs used in tactical flashlights that last about 20 hours?<HR></BLOCKQUOTE>
Klaus already said the most important things.
I want to add that actually if you get the wattage and the efficiency of a bulb, it does not say too much without the lifetime. You have to compare bulbs of a similar wattage and at the same lifetime to tell which one is the better quality.
Lifetime is the numbers of hours (usually) which 50% of the bulbs will life. That means half of the bulbs will fail earlier, the othe half later.
It was a good example for how you can forge technical numbers:
People wrote several years ago, that LEDs were more efficient tahn incandescents (which was not true at this time). But when you compare light sources of the same lifetime, you have to run an incandescent bulb pretty low to get 100,000 hours life. And under this circumstances LEDs where superior even several years ago.
