I recently got a good deal on Ebay on a Dorian Knurling tool (cut style):
But of course, the problem is that the shank is 1". Normally with less expensive tools, I would simply mill the bottom of the tool, but this Dorian knurler retails for about $900, so I decided cutting the tool would not be a good idea.
I have a piece of 4140 steel that I bought to make a parting blade cutting block, so I decided to make a new tool holder for the Dorian knurler:
Here you can see two BXA holders to compare their relative sizes:
So to the bandsaw I went:
I cut the piece I needed for the Dorian holder, plus the pieces I needed for the cutting blade holder (to be done in a future post/project):
Piece on the far left will be used for some future holder. Middle two are for the cutting blade holder, rightmost piece if for this project (Dorian 1" BXA holder):
I took some measurements on a BXA holder, to duplicate those on my new one:
I first started by making all sides flat/parallel using my 1.5" face mill cutter:
But I did not like the "split" finish (I had to do two overlapping passes), but the mill was not trammed:
Of course, this project took a little deviation while I finished the VFD conversion (thanks again Barry!), so I started by tramming the mill:
I then aligned the vice using the fixed jaw as you guys recommended:
Once ready, I used my new 3" 45deg face mill to lightly re-cut the 4 sides (not the ends):
(by the way, this is why you NEED a NEMA 4 rated VFD!!!):
To my surprise, I did not get the twin-cuts typical of a mill that has been trammed. As you will see below, the mill "IS" trammed, but not with this cutter!:
Here I am using a 1" twin-insert cutter, and sure enough, you can see the double cuts indicating the mill is trammed. My guess something is not aligned quite right on the 3" face mill:
So I keep making 0.050" passes until I got to the desired depth:
I then took a 3/4" Cobalt 6 flute end mill to clean up the edges and bottom of the slot:
With this end mill, you can again see that the mill is in fact trammed properly - weird:
And of course, the Dorian tool holder fits:
Here on a "standard" 5/8" BXA holder for comparison:
So I then start making the dovetail, using my Dorian 3/4" dovetail cutter:
First I have to cut a slot to the right width, so I used again first my 1" two-insert end mill, and then clean up with the 3/4" cobalt end mill:
After each step, I cleaned up the edges with a file:
I am approaching cutting the dovetail very slowly: cut, test fit, cut, test fit, since I wanted a nice engagement. First cut was a tad small as I expected:
After a few more passes I had it all perfectly fitted:
The new mill with the VFD is a REAL JOY to use - hard to believe I waited this long to do the conversion. Now the mill is really easy to use!. Here I am drilling/tapping the holes for the tool holder set screws (3/8-16):
After using a file to clean the top (and bottom that faces the tool):
Another test fit:
As I expected, I had to cut a small relief on the bottom of the holder to allow enough travel to center the 1" Dorian tool, so here I am using my 1.5" end mill to take the 0.20" off:
Used a file to clean up the edges (no sharp corners anywhere!). By the way, I am using Brownells T-4 to "blue" the steel block - it looks really cool in person, almost like the case-hardened frame on a Ruger single action pistol:
Now it fits great:
And my first test of cutting knurling (just one pass, really light), on a 0.5" Al round stock before I went to bed last night:
I need to make another one of these 1" holders, but I think I will wait a little while - this was a LOT of work, but it turned out quite nice :twothumbs
Will
Another test fit:
Now it fits great:
Will
