snipinglight
- Joined
- Sep 2, 2006
- Messages
- 168
How do you remove the C clip inside the battery tube? It's damn.... err tight and hard to remove with damaging the anodizing.:shakehead
I find the easiest method is to use a smallish flat bladed screwdriver. Working from the head end, put the tip of the screwdriver at an angle so that one corner is under the lip of the snap ring. Then give the screwdriver a little twist to lift the end of the ring out of the groove while pushing down on it at the same time. Once you have the end of the ring started, just work your way around the ring by pushing down and when you're about halfway around it will usually pop out of the groove and fall out the bottom of the barrel.
Why do you need to remove the clip? The switch assembly should fall out the bottom of a modern Mag without having to deal with it.
The older Mags have a screw-in top plate instead of a clip (first aluminum, later plastic) which does need to be removed to pass the switch through the top.
You need to remove it for things like inserting a KIU and/or AWR's Hotdriver.
Dont like to insert from the tail end, very troublesome.
