Robin24k
Those are only 3400mAh, but if you have a need for the power bank functionality, that's something the other ones won't have. However, these may not work with lights that require high-discharge cells since Maglite wouldn't have needed this for their lights.How does the Surefire 18650 compare to Maglite's?
When the Fury DFT came out, there were some issues with batteries that could not support the required discharge rate:
Below is the customer service info mentioned by dano.
Dear Customers of the FURY-DFT and M600DF,
When we launched these products our instructions were not clear regarding which 18650 batteries to use, and for that we sincerely apologize. Some customers who purchased the FURY-DFT and M600DF have experienced their light shutting down just after activation when using a non-SureFire branded 18650. This is because the FURY-DFT and M600DF are ultra-high-output illumination tools that require a minimum 5A discharge rate from the battery...
SureFire has some more information in this article as well:
News
www.surefire.com
In short, if you are planning to use these cells in 1,200+ lumen lights, get the SL-B34 or SF18650B since these are known to work in high-discharge applications such as the MegaStream USB (1,800 lumens) or Fury DFT (1,500 lumens).
