Can I buy a complete Mag85?
NotRegulated
I have been reading all about the Mag85 and the bi-pin setups for a Mag 3D. Can a complete Mag85 be purchased or do I need to put one together? Where to purchase the whole turnkey unit or the individual pieces? Do I need to install a bi-pin receptacle or not? I'm still not clear on what needs to be done.
NotRegulated,
Complete Mag85's can be purchased, but you have to find someone who has all the parts.
I have sold many in the past month, but currently am awaiting some more bulbs and reflectors.
Watch Modified B/S/T for others.
Bill
With a LOT of reading you can piece together all of what you need. If you don't want to order parts from 6 different places you might be better off to buy a complete Magcharger and just switch out the bulb for a WA1160.
I forgot to add- the next time I see Stephen I'm going to try to convince him to start building these things for sale.
I wonder, what can you build one for if you built them in bulk? I mean, if you built, say 20 of them, how much would each cost to build? Looks like they usually go for just over $100. I'd imagine if someone could build them for ~$75 and have the customer supply the batteries, sell them for $100 plus shipping. Hell, the reflector is the most expensive piece.
I'm going one piece at a time. Right now, I've got the bulbs, the lens and the reflector. Now I need battery holders. Any available source?
OK...but for a Mag85 with WA 1185, the arrangement is three 3AA to D holders, right? The ones in the group buy are 4AA to D....that won't work with that bulb, will it?
[ QUOTE ]
[/ QUOTE ]
You replace one of the cells in the 4AA with a dummy cell.
Sigbjoern
so that's about $60, including dummy cells and three holders? That's a little more than I wanted to spend. Weren't the EL battery holders more like $5 each?
[ QUOTE ]
[/ QUOTE ]
You could instead go for an 8AA to D adapter plus an 1AA to D adapter:
http://thomas-distributing.com/nc-d-adapters.htm
That should be $20 plus shipping.
[ QUOTE ]
[/ QUOTE ]
Yes, but they are not very solid I think, and I also don't like the way they are designed. It may also be a long while before you can buy these again.
The Fivemega 9AA to D adapter looks mighty fine!
Sigbjoern
