the picture is borrowed I hope the chap dosn't mind....
I'm building 2 battery packs both holding 2x18650 2500 mah batterys in parallel can I charge them like the guy is doing in the photo:thinking: one battery pack for each channel:thinking:
As long as they are in parallel it's ok!
They will ballance one and another, as the weak one will always drag the good one down to a common level wich the charger sees. Given that they are fairly evenly discharged, ie not a fully discharged one combined with a fully charged one.
But double capacity takes twice the time so the net gain is = 0, nought, zero, zip, nill, nothing :shrug:
As long as the paralleled cells are within +/- 0.5 Volts of each other, it should work. As The Dane said though, there really wouldn't be much of an advantage.
My problem with that setup would be the WF-139. I know a lot of folks swear by them, but it's the ones that swear at them, that concern me.
