TITAN1833
does anyone know if there is a cree drop in module for this flashlight appreciate any help.
I would highly recommend getting 2 17670s. Just about any regulated drop-in module should be able to handle that, including the ones for ~14 from Dealextreme. 2 17670s will be the same dimensions as the 4 CR123s. Even if there's a regulator that can handle 12+ volts, DC converters are inevitably more efficient when the input voltage is closer to the output as there's less "converting" that needs to be done to it. Also, 17670s should have slightly more usable energy content than 4 CR123s (less space taken up with packaging etc) so both of these facts will lead to better runtimes even assuming you find something to work on 12V (although a 3-emitter module would be nice )Strauss said:There are a few CREE drop-ins out there, one being from lighthound which is the one I purchased. I am not sure if the module will fit into the head. Also, it is rated for 3.7-9V. But you could just run 2x17670's to keep your voltage in check. So I guess all you need to find out is if any of the modules will fit inside the ultrafire head....
