sed6
I have a Cyclops 18 million CP spotlight which I modded last year with a 35W automotive HID. It was a fun mod and puts out lots of light. Looking at some of the other HID's like the POB, Twin Vector and Maxabeam's I wonder if it's enough? Well of course it isn't and I want it to be more powerful. I've read about overdriving various HID's, like Mac's 10W to 14W or some 35W to 50W applications. Is overdriving an HID as simple as supplying more voltage to the ballast?
Here are the specifics about the HID light and ballast I have in my Cyclops:
CERTIFICATION: E-MARK AND ISO9001
POWER CONSUMPTION: 35WATTS
VOLTAGE: 85 +/- 17V
LUMINOUS FLUX: 3200
BALLAST CONSTRUCTION: INTERNATIONAL IGNITER
SERVICE LIFE: APPROXIMATELY 3000HOURS
INPUT VOLTAGE: 9V-16V
WORKING CURRENT (Steady state): 3.5 A nom
IGNITION VOLTAGE: 24kV Peak Max, 18kV Peak Min
LAMP FREQUENCY: 450 Hz
Right now it's powered by the 12V 7Ah SLA which came in the Cyclops. Am I likely getting 35W from it now? If I up the voltage to 14.8 will it be brighter? Can I push the voltage past the specified 16V? If so how much? I don't have a power supply which I can use to supply a gradual increase in voltage. As such, bumping up the voltage would require an investment of time and money in a battery. Therefore I'd like to get it right the first time. I appreciate any input you have!
Here's link on eBay to a similar HID as mine. I have the H4 style in the 5000k temp.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=350095828815
Added these pics...click any pic for larger version.
The black mass is some sort of thick, pliable, rubberish compound. It was clearly poured in after the circuit board as evidenced by how it leaked through the board side. Can I, could I remove the black stuff?
VOLTAGE: 85 +/- 17V
LUMINOUS FLUX: 3200
