Perfectionist
- Joined
- Sep 10, 2004
- Messages
- 676
I use good old Militec-1 on my knives ..... would it also work on my lights ??
AArcVarc, that is extremely bad advice. Please do not give advice unless you know what you are talking about.AArcVarc said:Petroleum jelly bka Vaseline in the USA is all that is needed. You may use any lubricant you like and it all keeps the rubber o-ring pliable and the aluminum oxide at bay and resist moisture.
JML said:The compatibility of greases/lubes and O-rings depends on the material used to make the O-ring and whether or not the grease is built on petroleum oil. For that reason, it is generally best to stay away from vaseline and petroleum-based products. The safest thing to do is to use synthetic-base greases, such as Nyogel or Superlube, which will not attack the elastomer in the O-ring. Furthermore, you want something that will not "creep" and wick away from where it's placed -- vaseline can end up coating things far from the place you want it, esp. if stored in a hot environment.
