Can the M60 run on 1 Cr123?
¿o_O?
"Below 3.8 volts it will drop out of regulation and run direct drive." from Gene,
Can the M60 run on 1 Cr123? if so how much duller will it be?(noticeable difference)?
Extremely noticeable. A XR-E direct driven on 1xCR123 is quite dim.
If you want to use a single cell, look at the M30
Would be a very noticeable difference, with steep drop in output. Don't do it unless for emergency uses.
Bill
