Can the Photon 2 take the DL2025 battery ?
AlexGT
Houston, Texas
Was wondering how to increase the run time of the white or Turquoise photon 2, and looking for batteries found the DL2025 wich is 2.5 MM thick instead of the 1.6 the 2016 has, but with twice the Mah (150 instead of 75 )than the 2016, do you think it would fit ? will it hurt the led ?
Do you know of any button cell that are 20 mm by 3.2 mm and rated at 6 volts ?
Thnx
AlexGT
They don't fit, well not very well anyway. It makes the switch stick on and leaves a little gap in the case since they are thicker. You can make it work, but it isn't real pretty
I wish they made a double 2032 version for longer run times. It wouldn't be that much thicker.
Brock
