Can you really run the TK-10 on rechargeables?
kelsojack
I read a post on here with someone saying you can use rechargeable 123 batteries in the TK-10. I thought it wasnt designed for rechargeable batteries .:thinking:
That is super duper ,duper super!!!!!!!!!!!!!!! So why did they make the TK-11 then and do rcr123a's run as long as primary lthiums?
RCRs have about half of the capcity of normal CR123 batteries. So two RCRs result in an overall capacity of about 1300mAh. And that is why Fenix build the TK-11. Opposed to the TK-10 it runs properly with 18650 rechargeables with an capacity of about 2200mAh. So you get much better runtimes.
You can't run DX protected RCR's as the TK10 is designed around a CR123. A prot. DX RCR is larger than a CR123, so you need to use unprotected DX cells (lol no, especially since it's two in series) or 2 AW cells.
IMO TK11 is the way to go. Can use rechargeables for 2.5 hours or so on high, and CR123's as well (though also for about 2.5 hours on high!)
TK11 runs 2,5hrs with 18650, using CR123 it's less than 2h.
I agree the TK11 seems a better option on paper but I am yet to see output/runtime graphs from the respected reviewers here. I hope it turns out to be the same as the graph published by Fenix. If so I'll think I'll grab a TK11 too.
I run AW RCR rechargables, and i get 1 hour on full power, and i think 5 hours or less on low power
