candelas to lumens conversion?
  • Thread starter **DONOTDELETE**
  • Start date
D
**DONOTDELETE**
Guest
Just wondering if anyone has a simple conversion between candelas and lumens. Reason is that I'd like to compare the amount of light coming from a super-bright LED to that from an incandescent bulb.
I know that lumens are a measure of total luminous flux, and that candelas tell you the flux in the beam, so I think I need to integrate candelas over the solid angle specified for the LED beam pattern...or do I?
Any thoughts?
Thanks,
vince
You're real close! Here's the basics.
**IF** the light is putting out one candela over one steradian (solid angle where the area equals the square of the radius--there are 4*pi of these in a sphere) then the light is a one lumen light.
**IF** the light is putting out equal light in all directions and the light meter is reading one candela then it is a 4*pi lumen lamp.
Lumen outputs of complex lighting devices are measured in large integrating spheres.
Without knowing LOTS about the beam pattern, you cannot do the conversion.
Cheers,
Richard
There are a lot of companies advertising LEDs with very very high Candle output, but most of these achieve this by making the beam VERY narrow
Personally, I think Lumens is a better way to measure light output
