harrycolez
- Joined
- Oct 10, 2013
- Messages
- 43
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
2) Budget: An easy question, but you may change your mind after answering the rest!
____Up to $100.
3) Format:
____I want a flashlight (hand held/self contained).
4) Size:
____MEDIUM - Holster/belt ring carry. (>7 inches)
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____2 x 18650
____I want search and rescue type illumination (800+ lumens).
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____90-120 minutes (Runtime is moderately important, but still not critical)
____Any size switch will do.
____I don't care.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
15) Water resistance
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
____In house (temperature/climate controlled environment)
I've been looking at the Crelant 7G5CS and the Fenix TK35 (and the Sunwayman T45C) but can't decide on the flood or throw. The Crelant has more throw and has a longer runtime on high but is quite a bit bigger.
It is for outdoors in the desert where there are mostly open but hilly areas.
So what does everyone think? Flood, throw, or a different light?
Thank you for your time
____Up to $100.
3) Format:
4) Size:
6) Manufacturer:
____2 x 18650
____I don't care.
