I have recently installed a solar panel, charge controller, and small battery in a cabin on Mt Magazine, AR and need help with the lighting.
In looking for a low volt/draw lighting solution I have purchased and tested a variety of LEDs, flourscents, and most recently a dual CCFL tube made for pimping computer cases found here:
http://www.j-right.com/html/ccfl_pc_stand.htm
The small CCFL tubes put out a really nice 360 degree light for the main room but I would like to be able to dim them to save power and produce a sleeping night-night environment using a PWM circuit behind a wall plate switch.
Does anyone know of either a 12V CCFL inverter that is dimmable or has reference to a dimmable circuit that can be built to drive CCFL tubes?
