Chamfer Tools
mototraxtech
I want to make 45 degree chanfers on all of my parts. Its the standard degree that I have chosen. How do you all do you chanfers. A special tool or just angle your compound slide. I tried the whole compound slide thing yesterday and it took forever to change it to the right angle for all the chanfers. I was looking at the scmt holders that use a square bit and a point which would be a 45 degree on either side but the only holders I could find are 80 bucks a piece. So what do you do to chanfer things.
Thanks!
You have not told us the material you are trying to bevel nor the speeds you are trying to achieve, but I would suggest to forget about moving the compound angle and just grind your own 45 Deg chamfer tool from W1 drill rod. Here I am using my hand made tool (60 Deg) to bevel the edge to provide protection to the o-ring in a Mag tailcap:
Doing your own is very easy with a home grinder an cheap propane torch:
- pick a OD that works well for your needs (say 0.5" or 5/8")
- grind the tip to the shape/angle you need
- get it really hot with the propane torch
- as soon as it turns red dump it on a water bucket (right now it is too brittle)
- once it is cool, place it on the oven at 300F for about 25-30 minutes (more tough and less brittle now)
- remove from over and let it cool by air on its own
I have been using the one above for several months on soft Al and I have not even touched up the edge yet ;)
I just use a normal TCMT based tool and turn the tool post 45 degrees. I have a small triangle (part of an angle block set) that has a 45 degree side, so it's one wrench and a quick alignment to get 45 degrees. I also have a similar triangle with 30-60-90 degrees and, of course, machinists squares.
Of course, the trick is to make sure that you are measuring against a known surface that is on the same plane as the axis of rotation. In my case, I always put the compound back to 0 degrees when not cutting tapers. The leading edge of the plinth has been checked to ensure that it's aligned when the compound is aligned.
Daniel
Using any form tool (where the tool shape is a negative image of the desired form) does work on soft materials like aluminum, and on harder materials - as long as the depth of cut is shallow. As the DOC is increased there is a tendency for the tool to chatter since the edge contact area increases as DOC increases.
For a wide or deep chamfer, better results are obtained if the point of a tool is fed across the surface, using the compound to set the angle.
We are talking many different materials but a very shallow cut of only .02" to maybe .04". For now I can use the angle as long as I am doing many chanfers at once but when I would like to get a tool for it. I found a square bit holder on mcmaster for about 50 bucks but I am worried the bottom would hit on inside chanfers. I like the drill rod but I have NOTHING to grind bits with nor the place to but anything else. That's why I like the insert tooling so much.
No need to spend that much money in indexable tooling for chamfering.
Like Daniel I used to use TCMT tools for chamfering but I got tired of having to angle the TP to get a 45deg chamfer since it's a 60deg insert.
Just pick up a D style brazed carbide tipped bit from your local tool supplier or any online tool supplier for $3. The D style is an 80deg so that will get you pretty close to 45deg leaving the TP square with the spindle.
Grinding your own tools is great & a great feeling but at $3 (or close to $10 for USA made) for a carbide tipped tool it's well worth the time saved. I've been using the same tool from acetal, steel, titanium & it still has a nice sharp edge for cutting softer plastics & it's C2 grade too.
