Streak
I have received a R123 and charger. The charger is based on the MC34063 DC-DC step down regulator. The datasheet says that the Vout is set by adjusting two resistors whose values are currently 2.2k and 1k giving an ouput voltage of 4v. Indeed when the charger shows charge complete the battery measures 4.0v.
I would like to get a bit more into this cell and get the charger to cutoff at say 4.2v. This would mean changing the higher resistor value to about 2.36k or the lower one to about 932 ohm.
Firstly is it worth the excerise?
Would the cell be OK with the higher cutoff voltage?
Could I use a 1/8w carbon resitor instead of the SMD one on the board?
TIA
Streak
TIA
Streak
