nope it wont
that charger is 250ma but it pauses to check the voltage, so it is averaged current of 220-230 . there is some loss in charging, and so therin you will get about 2200-2300 max from full discharged battery.
its still a good little charger being slow and all, peaks out enloops beautifully. and still would work , if you use the discharge feature, then all the cells will have almost the exact capacity and no overcharge. they just wont be 100% charged. if you just use it to top off, and cells are therin at different levels, they wont work in series well. if you "reset" it and double charge the batts with a second run, for 8hours SOME of the batteries will be slow rate overcharged, which will not destroy them, but isnt nessisarily great for them either. (some of them will terminate)
it will work beautiffuly with enloops, given a discharge before charge.
but then your just going to send that back, and get a Timed 350ma 12 hour one (the one with no termination other than time), and the overcharge at 350 isnt going to be pretty either, because your in the CHEAP range of chargers that wont do well with a 2700 .
there is a 500ma and 800ma version of that thing, in at least a 8cell , because they are tight with the termination, the "fast" version of that style of charger should be better, it will charge them full up, and terminate usually properly because the rate is higher. about the same price, 2 less cells to charge a a time, and the best exchange $$$ for what you have.
it is either that or you get up into the $80 chargers (when doing more than 4 items), that work in more conditions correctally.
did i mention that they ALL have various issues
so pick your poisen.
