hi, i was wondering, its there any problem in charging 10 AA battery in parallel, that i may not be aware?
i will buy the 10 battery at same time, (no new/old mixing) and will perform the "conditioning" to make them as even as possible (discharge independently till 0.9v, charge all at 0.1C-16h).
as my hobby charger (turnigy accucel-6) can do 6A charging (about 3.6C) the -dV will be small, but as i have the the serial>USB cable, i pretend to do a "manual" end-of-charge, by analyzing the graph.
may also use a contact thermometer also.
is there any problems in this scenario? :duh2:
also, on side-question, i was aware that when the -dV happens, technically, the battery its already overcharging. my question about this, is, "where" in the voltage climbing, stabilize, and then drop, its the best point to end charge? keeping in mind my goal is longevity, not so much capacity. (will use them a lot, an would be nice if they can last about 400 cycles at least. they are 2200mah LSD cells - hobbyking turnigy)
tnks in advance.
tnks in advance.
