RipplesOfLife
Does this really work well? (when there's no other way to charge your batteries)
I went cycling today, and when it was night time, I turned on my backlight and nothing. And I don't remember it being dim the last time used it. But I may have left it on.
When I got home, I checked the light with other batteries and it worked.
Anyways, I put a fully charged battery parallel to the dead battery and connected + to + and - to - for about 5 seconds. And seemed to have charged the battery up. (well, at least it got the light working)
Is there any real harm in doing the above? Both batteries are AAAs but the one is of a higher capacitance. Actually the fully charged one was a NiMH and the dead one was a NiCad.
Now logically, if the fully charged battery was of 1000 mAh and the dead battery was 500. Then if the dead battery was giving enough time to fully charge up, the result would be that both batteries will end up with 500 mAh in them?
I think to make it a bit safer would be to put a resistor in parallel(?) as well. And of course, best not to try this with a lithium battery.
