jlomein
I am planning a ROP high built into a 2C Mag, powered by two AW C sized LiIon cells. I recently found out that although the Ultrafire WF-139 charger can be modified to touch the contacts on a C sized cell, it is not safe to charge with it.
The WF-139 has two independent charging channels that output 450mA per channel. AW states that his C sized cell (3.7v, 3300mAH) has an optimal charging rate of 2.0-2.5A.
He recommends RC type chargers called the Triton or ICE, however they are very expensive. Are there any cheaper charging solutions for these cells?
