Buck
- Joined
- Jan 14, 2007
- Messages
- 141
I have some red and green 4 x 5 mm LED Lite brand 3AA lights that I use as bow aspect lights on my sea kayak. They're OK, but the original O-ring seals were laughably loose (I replaced 'em with thicker rings, sanded down a bit to fit), and the copper strip from the - terminal is grooving the heads' contact areas enough that I don't expect them to last forever.
I've found few red and green LED lights on offer. (I've seen the TekTites.) I hate filtering white LEDs. It seems crazy since red and green LEDs have been around longest. I'm looking for a suggestion for a decently water-resitant Luxeon I light that either comes in red and green versions, or can be re-lamped with red and green Luxeons by someone with limited soldering skills and a cheap pencil iron. Needs to be pretty reliably dunkable, since a little sea water should go a long way in killing electronics. :devil:
A look in the archives turned up a comment that the Element AAA is easy to hack, but the 2-pack I found on Amazon does not show any claims of water resistance. Any other suggestions or tips? Also, a good source for the new Luxeons?
TIA,
Buck in Seattle
TIA,
Buck in Seattle
