Checking the charge rate - etc
old4570
Melbourne - Australia
A little DIY didly on checking you charge rate , termination , and for trickle charge ...
The charger has completed charging on one channel ...
To check if there is a trickle charge or full termination ...
Place the negative end of the battery on the negative tab ...
Then place the negative probe from your MM on the positive battery
Then complete the circuit by placing the positive probe to the positive tab on the charger ... In this case the reading is 0.00 due to the fact the channel has been turned of as the battery is charged ... Full termination ...
If you get any sort of reading what so ever you have a trickle charge ...
And I also use this method to check the charge rate ....
Hope this helps ....
