hank
One of my old MagD lights has a patch deep inside where an alkaline must have leaked long ago, and now the area's going dusty and pitting.
No idea when it happened, haven't noticed any problem, or had a battery leak, but something started eating it.
Either there was something corrosive left in there that apparently never got clean enough or there's enough outgassing from the batteries inside to make a clean but bare metal spot corrode further.
What's the best way to clean it out? (I've just swabbed it out with water and let it drain dry). Then to recoat the inside? Ordinary aluminum-grade primer paint, I'd guess, but I'm not sure if there's chemical corrosion in the pitted areas that I need to do more about.
I am guessing these are just black-painted metal, nothing special, I can see the edges of the paint peeling a bit where the corrosion happened.
