i agree with jzmtl
with some aluminium reflectors, they are really delicate, for example surefire's and the Mc-R reflectors, if u look at it wrong, it will peel off
the surface is way too sensitive to any debris and particles that can scratch it
the best method i have found is, a blast with canned air followed by drying in a sealed box.
The other method if there are oil deposits are to use an alcohol bath, swirl the reflector in the alcohol bath, but dont let the alcohol evaporate from the reflector, they can leave deposits as it evaporates ( found this out with my Mc R reflectors) thats because most alcohol we use are not pure alcohol, they have some additives , even the ones sold at the drug stores, and its these additives that are left behind when it dries,
To remove the alcohol, swirl in bath, then hold a tissue on the edge of the reflector and let it wick the remaining alcohol away, then finish with canned air.
the trick to using canned air is not to blast the reflector directly, but to gently pulse the air, just enough air to dry the surface rather than blast it directly, which can carry particles to be deposited on the surface again.
Some reflectors are really sensitive while others are not. YMMV with cleaning.
Best thing is this, a finger mark on a reflector does not affect it enough for you to notice, its better to just leave it be, rather than screw it up and have to buy a new reflector.
