CLOSED WTS: Brightest Regulated M2500 P60 LED (Beam Shots)
Status
Not open for further replies.
PursuitSS
Northwest Missouri
Re: SOLD WTS: Brightest Regulated M2500 P60 LED (Beam Shots)
So for a noob on this forum, for ~ 100$ i got flashlight? not only some parts right?
No, this is for the "pill", the LED assy. that installs in your P60 host. If you read through the whole thread you will get an idea what is needed to complete a assembled light using this LED.
Don't feel bad, so much on this web site is so far over my head I usually wind up with a headache reading posts here.
Skylumen
light engine only. You will need a host such as the solarforce L2T
Tracker II
Hi Vinh
I just sent funds for a de-domed, engraved, default (2-25-100%) drop-in with the driver that reverts to low as long as it was in any mode for more than 1 second. You da' man!
Dennis
weklund
Orange, California
M2500 P60 arrived today.
Simply stunning.
Default level separation is perfect for my needs.
Very pleased with this one all around.
Many Thanks.
revilo951
How well would this go in a P60 host headlamp?
psychbeat
SF norcal
I haven't put mine in my KAVElight p60 head lamp because I've got it set up for 4.2v
It would be awesome tho.
Especially my dedomed one :)
RCantor
KC, MO
Kevin can send you an insert for the battery pack to make it 2S2P. You could almost have an MM15VN on your head. :)
psychbeat
SF norcal
I've been tempted to rewire it myself and swap the connectors to xt60s from hobbyking.
Rewirong the holder would be super easy.
I'm still pretty happy with the Vanisledsm quad XPE2 4000K that Vinh suped up for me and the mule 4000K XML flood combo I have in mine.
Tho dual MTG2 dedomed would be ideal!!!
beltrao
Curitiba, Brazil
Re: WTS: Brightest Regulated M2500 P60 LED (Beam Shots)
Good morning Vinh,
Sent payment for one M2500 P60 dropin with levels 2% - 25% - 100% (​no memory, always turning on at low mode).
Thanks for shipping to Brazil!
copperfox
RI
Vinh,
Are these LED's standard CRI EasyWhite, or 80 CRI EasyWhite? Are they M0, N0, or P0 bin?
Also, is it possible to make a single mode module with fewer AMC chips? Can you make 2.28 amp module (380ma x 6)?
Skylumen
morepho87
Vinh,
Is it recommended to run this drop in with 2x26500 IMR cells?
Espionage Studio
[503]
Vinh, I read every post in this thread. Is it possible to get option 1 in reverse? High, med, low, moon in that order?
Status
