D
**DONOTDELETE**
Guest
I can't find the thread where Gransee was talking about the silver/tin he would be using for the battery contacts in the ARC, and wanted to suggest the following material --
(I would sure like to know how to obtain some of this 'hard cobalt/gold' material, I'd crimp and solder it into all my flashlights where ever I could -- plus it has the advantage of being self-cleaning as the screen material rotates against a surface...)
(description is from the Actionlight website, thanks to Henry...)
"... On a conventional light, each battery contact is composed of a bent piece of metal. Because the bent piece of metal is necessarily stiff so it can hold it's shape, it will only touch the battery at one or two points with a tiny contact area and a relatively high contact resistance. The Action Lights, by comparison, use a flexible screen material that provides dozens of parallel contact points and a consistently low contact resistance. The contact material is a hard cobalt-gold especially designed for low resistance electrical contacts..."
...see more under 'battery contacts' at: http://www.hdssystems.com/ActionLightTechnology.htm
