Coin Cell Charger for 10180
darkzero
darkzero
Flashaholic* ,
SoCal
AW recommends the Powerstream coin cell charger for 10180s. Does anyone have a good picture of it? The picture on their site sucks.
Any other chargers out there that I can use besides R/C chargers?
R
Raymond
Netherlands
how many batteries do you need to charge?
What is the capacity of an 10180?
darkzero
darkzero
Flashaholic* ,
SoCal
Charge just one at a time but I have two. 90 mah is the capacity. Both my nano charger & WF-139 are rated at 450ma so even charging two of these in parallel is not safe?
The Powerstream coin cell charger should be perfect, 40ma, but I'd like to see a clearer picture of it..
pyro
pyro
Germany
The link you provided shows a charger with 270 watts total power,
seems a little high for a 10180 :poof:
darkzero
darkzero
Flashaholic* ,
SoCal
Haha, yup that's would'nt be good. Something screwy with their site, I just copy & pasted the link in the address bar which is the wrong address. Link is fixed now. Thx
DM51
DM51
Super Moderator,
Supporter
Borg cube #51
Is this the coin-cell charger you mean?
darkzero
darkzero
Flashaholic* ,
SoCal
:party:
That's it. Perfect, that last pic showed me exactly what I needed to know. Going to order one now. Thanks DM51! :thumbsup:
DM51
DM51
Super Moderator,
Supporter
Borg cube #51
It's a good solution for charging a 10180. Some people have been using the 10440-size Nano-chargers, but the output on these is 200mA. That is >2C for a 10180, which is too much.
I can't say I've put too many cycles on 10180s through this coin-cell charger (fewer than 20 cycles) but it has worked well so far.
darkzero
darkzero
Flashaholic* ,
SoCal
It seems there are three different versions of the 10440 Nano cahrgers. The one I have looks different from the one AW sells & has a different p/n. Mine says .45a on the back. There's also a black version too that I do not know the specs on.
DM51
DM51
Super Moderator,
Supporter
Borg cube #51
I think yours is the RCR123A version - look at the size of the battery bay. 0.45A (450mA) is the output of that one.
The black one is the 10440-size (AAA size) bay and is 200mA.
I don't know of a 3rd version.
darkzero
darkzero
Flashaholic* ,
SoCal
Mine is definitely the AAA size but I git it from KD. The p/n is NBC-A001. Mine is gray & says Nano on it but the case differs in shape & color from the gray Nano AAA charger that I bought from AW (which I gave to a friend). So I say 3 versions. The one I have, the common one that AW sells, & the black one.
Maybe they screwed up on mine & put the AAA size bay on a R123 charger when making it? The believe 200ma version has a different p/n from mine. Regardless, my nano doesn't charge my 10180 batteries anyway. Light turns from green to red when the battery is inserted but no power output. :thinking:
DM51
DM51
Super Moderator,
Supporter
Borg cube #51
Sounds like maybe you have a knockoff, and not a very good one, at that.
darkzero
darkzero
Flashaholic* ,
SoCal
Probably, I wouldn't doubt it. It's in the trash now anyways. Thanks for the help.
xcel730
xcel730
NY
This is exactly the thread I was looking for. Surprisingly, this is one of the very few moments where the searching function gave me something I needed. :laughing:
Does anyone know approximately how many times I can charge a 10180 before the cell dies?
DM51
DM51
Super Moderator,
Supporter
Borg cube #51
If you don't over-charge it or over-discharge it, or run it at >2C, you should get >500 cycles out of it.
xcel730
xcel730
NY
Thanks DM51. That's what I thought too, but asked because I misread you when you said,
"I can't say I've put too many cycles on 10180s through this coin-cell charger (fewer than 20 cycles) but it has worked well so far. "
I read it too quickly and thought you mean you can't put too many cycles on the 10180. This is what happens when you're reading CPF late at night. :sleepy:
DM51
DM51
Super Moderator,
Supporter
Borg cube #51
My apols - Obviously my post was open to misunderstanding. I just meant I haven't used it very much yet. I'm anticipating it will continue to work well for a long time to come.
J
jojobos
Massachusetts
I know this is an old thread but.. I just got the coin cell charger from powerstream. http://www.powerstream.com/licoin-charger.htm
On the website it says "Charge rate is 40 mA"
However, on the back of the charger says,
input: AC180-240V 50HZ
output: DC 2.8-8.7V 250mah
Suitable for 200-3000mah
Can this safely charge 90mah 3.7V 10180 cells? Or did I get the wrong one?
Thanks.
Similar threads
De-Lux
Replies
26
Views
12K
rider
R
M
Replies
1
Views
896
VidPro
V
vic2367
Replies
6
Views
1K
vic2367
vic2367
B
Replies
3
Views
2K
m4a1usr
M
