MrAl
Hi there,
A friend picked up a Cold Heat soldering iron recently
(made by Coleman) and i tried it out. I liked it enough
to go get one ($16 at Costco). I decided to write this
post up for the benefit of others that might be considering
one of these soldering irons.
Pros
1. From the time you pick up the tool till the time you've soldered a joint
can be as little as 5 seconds even though the tool isnt hot when you first
pick it up.
2. From the time you stop soldering till the time you can touch the tip without
getting burned is about 1 to 3 seconds.
3. Works very well on thin wire like #22 gauge.
4. Works very well on quick and not too critical work, like soldering
aligator clips back on when they break off (like with clip leads and meter leads).
5. Has a nice white LED on the bottom to light up the work piece, but may need
directional adjustment on some tools.
Cons
1. The tip has to make very good contact with the work surface. This is
sometimes very difficult to achieve. It requires moderate pressure and
if the piece can swing a little it's hard to keep the tool contacting
the work piece satisfactorily. It works, but it may take time.
2. Metals like copper corrode when heated, so if reliable contact isnt
made the metal may need cleaning with a knife or something. This isnt
hard to do but it's another problem. There are times when you try to
solder and the metal corrodes again so you have to clean again. The
best approach is to anchor the piece somehow so you can apply firm
pressure with the tip.
3. There's no limit on the heat output so the piece can possibly reach
red hot temperature. This can damage some parts so you have to make
sure to pull the tool back or finish quickly.
4. Tip is fragile. New tips are $5 plus $3 shipping, so that's $8.
If the tip becomes damaged it wont solder until it's replaced.
5. Cant be used on parts where a bridge across two pins of the part may
occur because the tool will pump massive current through the device.
It may be possible to be very careful about soldering these kinds of
parts, but even the manual states that it's mainly for moderately
sized parts. A workaround is to make ABSOLUTELY sure that the tip
never touches two pins at the same time, nor even a part's lead and
a solder pad because the tool can pump current through the part and
the trace connected to the solder pad on some circuit boards.
Ditto with a joint that is the last joint where something turns on
once the joint is made -- bridging might occur which could burn something
out. In general, mucho caution required, but it's possible to do.
6. The manual says they dont recommend rechargable batteries.
Recommendations
This shouldnt be your only soldering iron unless you only intend to
solder clip leads and do wire splices and stuff like that. If you're
going to solder ic's regularly you really need a 'regular' iron. Works
ok on resistors, even small 1/8 watt ones. Transistors with long leads
should be solderable also, but beware surface mount parts.
If you're going to solder very heavy work you'll need a big iron.
Take care,
Al
Pros
pick it up.
Cons
Recommendations
Take care,
Al
