ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just received the Coleman CREE Mini Headlamp from The Gear Revival. After the review is finished the light goes back to the The Gear Revival.
You can purchase the Coleman CREE Mini Headlamp at The Gear Revival.
Use code CPF10 at checkout for 10% off your order, including anything else from the site.
Order over $100 worth of items and get free UPS Ground shipping in the US (no code needed, despite what the homepage says).
Get a free Nalgene bottle on orders over $85 (no code needed, we just throw them in orders until we run out).
There is a thread on the Coleman Lights at CPFMP
Costs $39.00 before discount.
Uses Cree XRE.
2 hours on high. 7 hours on low.
High, low and emergency strobe.
Uses an optic. Has the typical optic beam, slight ring and not a very smooth beam.
Tint of the beam is on the slight yellow side.
Small and compact. Feels very light on the head.
Uses 1, CR2 Duracell Lithium Battery.
Comes with CR2 Duracell Lithium Battery.
Comes with warranty. Instructions located on package.
Uses an optic.
Headlamp can angle in 4 positions. Clicks in each angle.
On off switch switch located at the rear top of the headlamp.
Rubber pad forehead cushion.
Rear battery cover removed.
Inside view of the rear battery cover.
These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using the Duracell CR2 that came with the light.
Coleman CREE Mini Headlamp, High - 640 lux @1 meter
Coleman CREE Mini Headlamp, Low - 150 lux @ 1 meter
Coleman CREE Mini Headlamp, High @ 1 meter
Uses Cree XRE.
Uses an optic.
