M
mattw
- Joined
- Apr 22, 2009
- Messages
- 87
First off, if this is in the wrong place... move it please!
I am collecting parts to build my first P60 module. So far, it looks like it will have either a CREE XM-L2 T6 4C or CREE XM-L2 U2 3C mounted on a Noctigon copper board. Since I plan to drive it with 1x18650 high output cell I have selected the QLITE REV.A 7135*8 3.04A LED DRIVER with NLITE firmward and a 120 second automatic step down. I have selected the above LED's because of the neutral white tints.
I have not selected an actual module to build it on, I may gut a Solarforce for lack of a better donor. If there is a shell that all of you could recommend that is roomy and well designed, let me know. I think I will go with a smooth reflector to maximize throw.
Now, for the questions... I do not fully understand potting the led for strength and I see that people use heat transfer grease or epoxy in the process. I assume that this goes in between the driver and the pill and the LED and the pill? I would also need something that would allow better heat transfer from the LED to the reflector and at the same time to prevent the reflector from shorting the LED.
I know, this is re-inventing the wheel... but I want to try the process, so that in the future I can work with other LED's that may have a tint or output level that I like and drivers that can be programmed or support a good 4 mode option.
I think I am on the right track, but would like some confirmation from the experts here.
Thanks Matt
Thanks Matt
